disable snmp traps ospf
Description
Disables the OSPF module from sending traps on various OSPF events.
Syntax Description
Default
Disabled.
Usage Guidelines
None.
The following command disables the OSPF process:
This command was first available in ExtremeXOS 12.6.
Platform Availability
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
